It is currently Sat Aug 02, 2025 7:31 am
 Post subject: Behlen's Lacquer
PostPosted: Sun Mar 24, 2019 6:05 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Is it me? Why am I having trouble locating this product?
 Post subject: Re: Behlen's Lacquer
PostPosted: Sun Mar 24, 2019 6:19 pm
http://www.woodcraft.com/products/behle ... 3MQAvD_BwE
If your not done building guitars you might want to buy it by the gallon from Mohawk:
http://www.mohawk-finishing.com/product ... nt-lacquer
These users thanked the author Clay S. for the post: Mike OMelia (Sun Mar 24, 2019 6:26 pm)
PostPosted: Sun Mar 24, 2019 6:27 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I appreciate that. I have normally just bought off Amazon (at least that is where I thought i bought it, no record)
PostPosted: Sun Mar 24, 2019 6:37 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Clay S. wrote:
http://www.woodcraft.com/products/behlen-luthiers-lacquer-quart?gclid=CjwKCAjw1dzkBRBWEiwAROVDLEjSMVG97PyvsmK_ZJGsxHHK8u1BGTxDXihCeVWdnlDrgAB8Ra3MBBoC63MQAvD_BwE
Is that the same as Behlen? I am SO confused. I have been buying Behlen gloss, can't find records
PostPosted: Sun Mar 24, 2019 6:53 pm
Last Name: Beaver
City: Lake Forest
Seem to recall that Mohawk now makes Behlen. When I look at the Mohawk site, they have some Behlen products listed.
Joe Beaver
Maker of Sawdust
PostPosted: Sun Mar 24, 2019 7:06 pm
I have been using Mohawk for a number of years now, but about a year ago I ran out and bought a quart of Behlen's to hold me over until I could get to the Mohawk distributor to pick up a couple of gallons. Some one had said Behlen's was either Mohawk or Sherwin Williams stuff rebranded. (Mohawk is probably S-W rebranded also) Behlen's smelled the same and worked the same as Mohawk.
I use the gloss finish, but you can buy their finishes in different sheens ( in spray cans also if you don't want to buy a whole lot).
www.mohawk-finishing.com/products/wood- ... ce-clears/
PostPosted: Sun Mar 24, 2019 7:29 pm
First name: David
Last Name: Riedmiller
State: WI
Mohawk does indeed make Behlens. I’ve used both. If you want a great nitro lacquer buy Cardinal paint’s nitro. Lower cure time and a bit more scratch resistant. I’ve also found its performance in spray application to be better. My nickels worth.
"It is easier to fool a man, than it is to convince him that he has been fooled"
Mark Twain
PostPosted: Sun Mar 24, 2019 7:36 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Well, I just bought a gallon of Mohawk Gloss. We will see, model number almost identical. Seems I've been down this road before.
PostPosted: Sun Mar 24, 2019 7:42 pm
I like the Cardinal lacquer too. Best I have ever used. Much better than the old McFaddens. A bit pricey though.
PostPosted: Sun Mar 24, 2019 8:04 pm
Last Name: Livermore
State: Minnesota
Have used Mohawk for years. THis Distributor is solid, and very knowlegable. Any questions you have, they can amswer. If you want to know if it is the same as Behlen, they will be able to tell you.
https://www.westlunddistributing.com/to ... cquer.html
PostPosted: Sun Mar 24, 2019 10:09 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Thanks guys, appreciate it. I bought the Mohawk. I’ve def punted on wateborn. My last batch of Enduro Var was a nigthmare. Nitro is so simple, so basic. So repairable.
These users thanked the author Mike OMelia for the post: Pmaj7 (Tue Mar 26, 2019 4:00 pm)
PostPosted: Sun Mar 24, 2019 10:10 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
...still, it seems I’ve bought Behlen blue print cans forever. Did they just change the label?
PostPosted: Mon Mar 25, 2019 5:51 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Same product (M610-1407), just available at a much better price directly from Mohawk, and in 1 and 5 gallon containers (same thing with EZ Vinyl Sealer, M610-8007, $30.68 as of October 2018). You may wish to establish a business account with Mohawk Finishes, which takes just a call to them. With shipping from North Carolina to DC/Baltimore/Northern VA area in 4 to 8 gallon orders, about $42 per gallon ($33.70 plus shipping).
We have a local distributor that quoted over $55 per gallon for Classic Instrument Lacquer, so we continue to order direct through Mohawk's online portal.
- Beth Brower
These users thanked the author Woodie G for the post: Pmaj7 (Tue Mar 26, 2019 4:03 pm)
PostPosted: Mon Mar 25, 2019 1:13 pm
I got a high quote from the local distributor in Wilmington. When I told him it was $32 online, he came down to $39, which was better than the online price + shipping (but not by much). Sometimes you feel like they treat you like the gorilla who walked into a bar.
www.reddit.com/r/Jokes/comments/5jadvv/ ... nto_a_bar/
PostPosted: Mon Mar 25, 2019 6:53 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Well, if the Mohawk is same as Behlen, I'll be a happy camper. Is cardinal higher percentage solids?
PostPosted: Tue Mar 26, 2019 5:48 am
not all water lacquer is the same Em6000 works very well.
Also Minwax lacquer does a great job.
While not all finishes are the same they do have some basic qualities.
I used Behlen and Mohawk for years but with the chipping issues I had started mixing
minwax into them and it works well. That solved my chipping issues.
PostPosted: Tue Mar 26, 2019 10:50 am
Hi John,
Was that the minwax brushing lacquer? What ratio did you mix it?
I haven't noticed a lot of chipping from the Mohawk product when sprayed over epoxy or bare wood (self seal) but it is nice to make a product better if it can be.
I have run into compatibility issues when spraying some lacquers on top of others, so I have avoided mixing them together.
PostPosted: Wed Mar 27, 2019 3:47 pm
I uses the blue can and mixed starting at 10% and went to 50% polishes nice worked well that I even have use straight minwax from my local hardware store they can only get it in 1 qt cans but that if fine with me.
I also used thinner and byutyl acetate 20 % thinner 10 retarder .
These users thanked the author bluescreek for the post: Clay S. (Wed Mar 27, 2019 6:03 pm)
PostPosted: Wed Mar 27, 2019 6:41 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
John, what chipping issue are u referring to? First I have heard of this?
PostPosted: Thu Mar 28, 2019 5:48 am
when drill holes or reaming it often chipped especially when clearing for the bridge. Many of my friends have the same issue. They reformulate this as the government dictates VOCs.
Even reamers popped finish off the tuner holes.
These users thanked the author bluescreek for the post: Pmaj7 (Thu Mar 28, 2019 12:31 pm)
PostPosted: Thu Mar 28, 2019 1:56 pm
Interesting on the chipping. I wonder how much of a widespread problem this is?
Sent from my SM-N910T using Tapatalk
PostPosted: Thu Mar 28, 2019 6:17 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
John, so you mix blue can minwax 50% and it works?
PostPosted: Fri Mar 29, 2019 5:55 am
yes it works wonderfully still takes a good 2 week to cure like behlens but I am very happy with the results.
I have been using LMIs water filler and the aqua coat. I think they are both excellent products. The aqua coat is so easy to use
and is ready to go in 45 min.
These users thanked the author bluescreek for the post: Pmaj7 (Fri Mar 29, 2019 1:12 pm)
PostPosted: Fri Mar 29, 2019 8:25 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Could u post a picture of the exact minwax u use?
also, what is Acqua Coat for?
PostPosted: Fri Mar 29, 2019 12:01 pm
aqua coat is a filler
